Basecamp Startup Error
KSza1
Has liked: 5 times
Been liked: 3 times
Re: Basecamp Startup Error
Post by KSza1 »
delete the cyclops file in the POI folder in the XT
Has liked: 382 times
Been liked: 384 times
Try deleting any cyclops speed camera files, that has worked for some according to posts on the Garmin forum
Has liked: 424 times
Been liked: 246 times
I will try that
I also have a cyclops update that keeps failing :?
JS_racer
Has liked: 9 times
Post by JS_racer »
I have a USCanadaCyclopsSample.gpi
do I delete that, it was a trial that expired.
thanks.
seems it still complains about the current.gpx
does the current gpx need to be removed every time before using base camp ??
this is crazy.
Has liked: 432 times
Been liked: 956 times
(Correction to original post)
current.gpx is used to store the routes that have been transferred to the Zumo and which have subsequently been imported. ie it contains the current list of saved routes in the Zumo.
You can get rid of its contents by deleting all of the imported routes from the Zumo Trip Planner App. Then plug in the USB cable and delete the Current File (or rename it as described below). While you are at it, get rid of temp.gpx. Temp.gpx coantains all of the routes that were trasnferred to the Zumo during the last USB connection with Basecamp. It gets overwritten each time you connect BAsecamp to the USB port and transfer more routes. (in effect it wipes out the previous transfers - which means the zumo will not be able to import them again.
nb this behaviour is very different from the 590 and 595). Then do a hard power off and restart, so that current.gpx is recreated. Check that there are no routes available to load, and that there are no routes available to import.
Then try again. It ispossible that a route that you had was corrupted on transfer, or perhaps you had a route that didn't originat in basecamp?
One other possibility is that the memory that current.gpx is written to is faulty. Instead of delting current.gpcx, try renaming that file to something else, eg current.old. Then do a restart. When the Zumo creates new current.gpx, it will be forced to create it in a completely new location, because the old file already occupying the memory that is suspect.
Worth a try.
