Basecamp Startup Error
VA3TWT
Has liked: 25 times
Post by VA3TWT »
Good day;
I get the following error when I start Basecamp (latest version):
"There was a problem communicating with the Zumo XT
An error occured while reading the following file(s):
gpx/current.gpx"
Anybody know what I did wrong and/or how to correct this error?
Thanks for any and all help;
Gord
Zumo 595LM
2010 GL1800 Goldwing
Has liked: 344 times
Been liked: 368 times
Re: Basecamp Startup Error
Did I answer this elsewhere? Anyway the solution is just delete the file
VA3TWT
Has liked: 25 times
Post by VA3TWT »
Any hint as to where the file is that needs to be deleted? I don't see a gpx folder or current.gpx file. Using Windows 10.
Zumo 595LM
It's in the GPX folder on your Zumo
mzeist
Has liked: 33 times
Been liked: 31 times
Post by mzeist »
on my windows 10 its in: This PC\zūmo XT\Internal Storage\GPX
Groet, Marcel.
ondras76
Czech Republic
Post by ondras76 »
I have the same problem and the solution with delete the GPX file in Zumo doesn't help :(
Has liked: 104 times
Been liked: 221 times
I've always had better luck with the 595 by having the computer do one thing at a time. I open BaseCamp and wait. It's a slow process. After a few minutes I plug my device in and wait again. It's an even slower process this time. Sometimes it can take upwards of 6 to 8 minutes for everything to work correctly.
ondras76
Czech Republic
Post by ondras76 »
Thank you, but still the same. Crash after the Zumo is connected. :(
ondras76
Czech Republic
Post by ondras76 »
so i found a solution. Helped to delete POI directory in ZumoXT.
Has liked: 414 times
Been liked: 229 times
I am also getting this error and have tried the suggestions here but nothing seems to work!
