Peobody wrote: ↑Fri Aug 12, 2022 12:22 pm
jfheath wrote: ↑Fri Aug 12, 2022 6:28 am
3 The top bar of the XT screen will show the same message as text.
I am hoping that number three works and that the XT doesn't change the name of that WP.
If you create the route point as a genuine Waypoint - ie one that has been created by the Basecamp flag tool, and/or one that has been added to the route on the XT using the Favourites or Saved locations, then yes the ViaPoint will keep its original name.
Curiously, the name of any point is retained if the route has been generated by MyRouteApp - for reasons that I have established
here
You might want to check on how many characters of the name are displayed across the top of the screen. Just try it out, Create a point called ABCDEFGHIJKLMNOPQRSTUVWXYZ, and see what letter it displays up to when you get close to it.
Links:
Zumo 590/5 & BC . . .
Zumo XT & BC . . .
Navigating with Zumo Booklet
