CN EU 2023.2 NTU is available
ChainsawDude
Been liked: 8 times
Re: CN EU 2023.2 is available
Post by ChainsawDude »
955Tiger wrote: Thu Jan 05, 2023 9:26 pm I have just updated my Zumo to City Navigator Europe NTU 2023.2 and run into a problem.
It looks like the map for the UK is the base map only while the European segments are the full maps.
I have tried reinstalling but it is always the same.
Anybody else had this issue?
Yes, I have the same issue with my Zumo 350LM.
Just the UK that is base map only.
So I tried a new sd card (so effectively deleting the map) and it downloads CN Southern Europe 2023.20 (should be Full Europe). I think it may have installed to the internal storage (not the SD card) and downgraded Europe to Southern Europe due to space, but not certain at this stage.
I am trying various different things because I thought it was just me but now I know others are affected I will contact support.
ChainsawDude
Been liked: 8 times
955Tiger wrote: Fri Jan 06, 2023 4:25 pm I have done a bit more digging and found that it is only the UK that is just the base map. If I look at France, Spain etc. the full details are present. So for some reason just the UK is the problem.
I am using a Zumo 390LM which I have had for a long time.
I have tried looking at the manage maps option in Garmin express, but despite using the lastest version of Express the option is not visible.
Exactly the same for me except I have a Zumo 350LM.
My first problem was the Zumo telling me it could not "unlock the map" but after some ill advised botched attempts to fix it I now find it is (re)installing "CN Southern Europe 2023.20" and to Internal Storage (8GB) (full Europe has to use the 16GB SD).
There is no "Manage Maps" button, only a "Reinstall Map"
I'm looking for a way to go back to "CN Europe" and make it use the SD card.
Please confirm what is showing in Settings, Map&Vehicle, myMaps
Note instructions for changing an installed map region are here https://support.garmin.com/en-GB/?faq=d ... kS9sU5xDcA
You need to scroll down to get to the correct instructions
ChainsawDude
Been liked: 8 times
sussamb wrote: Fri Jan 06, 2023 7:52 pm Please confirm what is showing in Settings, Map&Vehicle, myMaps
CN Europe NTU
2023.20 Southern Europe
If your refering to the Purchased tab in Tools & Content. That just says "There is no content for this device". There is also a message "We're having trouble retrieving all your purchased content."
My Avtex 660 which updated as normal also has the exact same messages and updated normally.
Then clearly you only have part of the map installed, there are instructions in the link that explain how to change it.
Here's a link to the video in that FAQ
ChainsawDude
Been liked: 8 times
Yes clearly and if I had a change map button I would try it.
The video has a "Change Map" button but my Zumo does not. After a "Reinstall Map" I still have just Southern Europe.
Latest garmin Express 7.15.2.0, tried both Windows 10 and also MacOS 13.1
Screenshot 2023-01-07 124908.png (403.71 KiB) Viewed 8316 times
Screenshot 2023-01-07 125133.png (134.18 KiB) Viewed 8314 times
Last edited by ChainsawDude on Sat Jan 07, 2023 12:52 pm, edited 2 times in total.
Then a call to Garmin Product Support is required
Just wondering...
This post is about installing the map on the device, but how is the map in Windows (Basecamp)? If it's really the case that the complete map is always installed on the PC. Could you then install the map via MapInstall from the PC to the Device? Maybe to a SD card first to see what happens?
It's installed to your computer IF you select the option to do so. You could certainly install the map from there to your device using BaseCamp but that only installs the map. Map updates for modern devices include far more than just the map, junction views is just one example, so it's generally better to get Express working.
Edit: just seen a post on a Garmin forum, member there had the same issue and resolved it by removing all maps and then doing a reinstall with Express.
ChainsawDude
Been liked: 8 times
FrankB wrote: Sat Jan 07, 2023 9:56 am how is the map in Windows (Basecamp)? If it's really the case that the complete map is always installed on the PC. Could you then install the map via MapInstall from the PC to the Device? Maybe to a SD card first to see what happens?
The map on the PC did not update after the failed Zumo update.
However the map on the PC did update after I updated my Camper 660 (another Garmin device that I have). That device updated with no issues at all on the same PC cable etc.
So the map on my PC is currently full Europe 2023.20. There is no method for me to transfer that to the Zumo.
