Service Provider Needed?
Has liked: 432 times
Been liked: 951 times
Re: Service Provider Needed?
The XT has a few weird routing behaviours - and for a long time they were annoying me / us. When you come across them, they will irritate you - and you will be back on here saying - "Oi - you said ......."
Yes we did, but that is because we have the answers that Garmin were unable to provide. So come back to us. My XT is now a very good bit of kit with just a little "know how".
Evo-Wes
Has liked: 8 times
Post by Evo-Wes »
Thanks for the heads-up.
_______________________
Regards,
Wes
Some days it's just not worth chewing through the leather straps.
1998 Harley-Davidson FLHTCUI 95th
Has liked: 71 times
Been liked: 191 times
Evo-Wes wrote: Wed May 01, 2024 3:16 pm I haven't yet finished reading all that has been posted. That is going to take a couple of days.
You might need more than "a couple" days. Some of the XT behaviors are not what you might expect. You will definitely want to read all twelve sections of this post in order to understand how the XT works.
Evo-Wes
Has liked: 8 times
Post by Evo-Wes »
lkraus wrote: Wed May 01, 2024 8:14 pm You might need more than "a couple" days. Some of the XT behaviors are not what you might expect. You will definitely want to read all twelve sections of this post in order to understand how the XT works.
I assure you that the links will not have been wasted on me. I am delving into them.
Regards,
Wes
BrAtKo
Has liked: 17 times
Been liked: 7 times
Slovakia
Post by BrAtKo »
My point of view, if you are looking for easy and user friendly GPS hardware without internet connected features and advanced knowledges, I suggest to change the mind and focus to different vendor or smartphone applications (with motorcycle routes there are few great).
Image Honda NC750S DCT fuel consumption (122 000km from 2015y)
denno
Post by denno »
Hi, seriously considering the XT2 for my Grand America. I've looked through the owner's manual but can't seem to find an answer to this....Can I connect both the rider's helmet and passenger's helmet to the XT2 to receive nav instructions or am I limited to one BT connection?
Thanks in advance for any info!
I have seen an option on the XT2 to connect a headset after one has already been connected, but have never tried it. I don't know if it will affect the phone capabilites. I'll find out. I have a pair of cardo packtalk Edge headphones.
The zumouserforums is shifting servers today so it will be offline until the world wide Web has updated its records to point to the new server.
I should have an answer by then.
Update to previous post.
Yes the XT2 will connect to two headsets. Satnav instructions and music will play through both.
Don't know about phone calls. Probably - maybe.
denno
Post by denno »
Thank you so much for verifying. This helps my decision a lot!
