Page 2 of 2
Re: No satellite reception in new house.
Posted: Sat Jan 18, 2025 2:57 pm
by colirv
Peobody wrote: ↑Sat Jan 18, 2025 1:34 pm
so I finally created an instructional text file.
Which, of course, you're planning on sharing!
Posted: Sat Jan 18, 2025 4:11 pm
by lkraus
Posted: Sat Jan 18, 2025 4:33 pm
by Oop North John
Mzokk wrote: ↑Sat Jan 18, 2025 1:06 pm
You can also tell your unit that you are in a different location in simulator mode. Handy if you are designing routes on another continent and you are using OSM maps or such.
I know of that feature. I got tired of researching (or being lazy and just asking) how to do it so I finally created an instructional text file.
From the on-line manual:
https://www8.garmin.com/manuals/webhelp ... D6D88.html
Posted: Sat Jan 18, 2025 4:42 pm
by Peobody
colirv wrote: ↑Sat Jan 18, 2025 2:57 pm
Here you go. I'm sure it's not original though. I apologize for not crediting the original source.
Setting a Simulated Location
If you are indoors or not receiving satellite signals, you can use
the GPS simulator to plan routes from a simulated location.
1 Select Settings > Navigation > GPS Simulator.
2 From the main menu, select View Map.
3 Tap the map twice to select an area. This zooms in the map.
4 Long press on the spot where you want to set the vehicle location.
The address of the location appears at the bottom of the screen.
5 Tap the location description.
6 Scroll down on the left of the resulting screen until you can tap on "Set Location".
