Page 2 of 2
Re: Basecamp a bit clunky
Posted: Thu Jan 23, 2020 8:01 pm
by Stu
CollingsBob wrote: ↑Thu Jan 23, 2020 6:14 pm
Stu wrote: ↑Wed Jan 22, 2020 1:29 pm
Anyone tried ITN converter?
http://www.benichou-software.com/index. ... =3&lang=en
I used it when I had a tom tom
I found the maps smoother than basecamp and adding waypoints to for the route just makes them shaping points but you still have to import it to basecamp to check which isn't a problem
Can ITN converter be used to convert a route created in Garmin Basecamp to Google maps?... I installed it but it wont import a .gdb file..
There is some issues with Google maps! They have changed their API terms and put priced a lot of people! As a result Google maps no longer works with ITN converter and a whole host of services!
Posted: Thu Jan 23, 2020 10:44 pm
by titter
sussamb wrote: ↑Mon Jan 20, 2020 11:39 am
Me too. I'll stick with 4.6.2 until they restore the GE link
I'm running version 4.7.1. I've found a link to download the older version, you suggesting I should download and use that if I want to use it in conjunction with Google Maps?
Posted: Fri Jan 24, 2020 3:13 am
by Iris
Yes. The 4.6.2 works with google earth.
Posted: Fri Jan 24, 2020 4:31 am
by CollingsBob
Iris wrote: ↑Fri Jan 24, 2020 3:13 am
Have you got a link to 4.6.2?
Posted: Fri Jan 24, 2020 7:20 am
by sussamb
Posted: Fri Jan 24, 2020 8:22 am
by titter
CollingsBob wrote: ↑Fri Jan 24, 2020 4:31 am
https://www.technoleros.com/download/ga ... amp-4-6-2/
