Re: Installing map to PC
Posted: Thu Apr 01, 2021 10:52 am
That is the state of play at the moment. The latest Garmin Express does not have a facility to download the map to the computer. At the time of writing, the latest version is 7.4.1.0 - damn - I just loaded Garmin Express and it tells me that 7.4.2.0 is now available.
Dare I risk it ?
Ok - here goes. I may be some time.
No 7.4.2.0 doesn't allow it either.
If you have an earlier Zumo registered with Express - eg a 590 or 595 (and probably 660 or 550 - although they didn't all come with lifetime maps), then the facility to install to the computer is available. They use the same maps, and the same installation works with both Mapsource and Basecamp.
The issue has been lodged with Garmin, not just by me, but I raised the issue on 16 March 2021. The last communication from them was on 18 March 2021:
We have added you into an open investigation which will be used to determine the cause of this issue which we are looking into currently. Using the information provided they will test and reach a suitable resolution which will then be supplied to you directly by email.
We cannot provide a time frame for this process as it depends on what is discovered during the investigation and what is required to resolve the issue.
Any updates will come to you directly via email as an affected user of this case.
The files are typically installed in C:\Program Data\Garmin\Maps and if that folder is renamed, then Basecamp cannot see them. If it is put back, it can. So I'm guessing that a backup copy of the entire folder would enable maps to be restored. There are plenty of lines that can be read between.
But - I have just noticed. In C:\Program Data\Garmin\CoreServices\Downloads|application there is a series of single folder names, at the end of which is a floder that seems to contain all of the previous versions of Garmin Express. I haven't tried them yet, but it may be worth a go.
Dare I risk it ?
