Page 3 of 3
Re: Where I've Been App
Posted: Thu Jun 06, 2024 3:57 pm
by danham
Mariannepm wrote: ↑Thu Jun 06, 2024 12:25 pm
Brilliant. Thanks a bunch. That definitely made sense once explained like that
Since you appear to know a lot more than me (not that difficult
...) would you know why my music keeps on coming on during trips? It looks like any type of notification would trigger the music to start playing from my phone library...I have a Zumo XT, Iphone and Cardo Packtalk Edge all connected to each other...
First thing to check: the XT needs to be the hub, meaning iPhone and Cardo paired to XT but NOT to each other.
Posted: Thu Jun 06, 2024 10:36 pm
Ah, now you are pushing your luck! And mine. I have never come across that issue, I guess your setup is slightly different from mine.
I have an XT, packtalk edge and an android phone. This has to be solvable though.
1. So How are your devices connected ?
Mine are connected like this.
Edge <=== (BT 2nd Phone)===> XT <=== (BT) ===> Phone
The Edge initial BT connection is unpaired / forgotten from the phone
2. Where does your music come from ? Mine comes from the Mp3 player on the Edge.
My early use of sound from phone to Zumo failed. sound breaking up frequently and then every second or so. I reckon that the phone gets interrupted by all of the BT devices in passing cars. Particularly since it works perfectly at my desk and when I first set off. After that, a dead loss.
Posted: Thu Jun 06, 2024 11:09 pm
by Peobody
FWIW, I have a Packtalk Bold an XT, and an iPhone. My experience with music on my phone is that the XT would automatically start playing it when the phone connected. I put the music on the XT's SD card instead. I then had to turn off (untick) the "Medio Audio" option in the XT Settings > Wireless Networks > My iPhone.
Posted: Fri Jun 07, 2024 9:42 am
by Mariannepm
Thanks guys, I''ll try those suggestions during our next adventure, hopefully over the weekend. Take care and your expertise and time were much appreciated.
