It seems to have cured itself. Not sure if it's me doing something different, or the XT2, or Basecamp. Or maybe a combination of all three!jfheath wrote: Tue Oct 15, 2024 4:43 am Did you sort this out @Oop North John ?
I forgot to say that Current,gpx seems to store most things currently available from the XTs screens. It is safe to delet but needs a reboot to create a new empty one. My instruction above would have deleted it anyway, but I didn't mention it specifically.
Anything not stored in there can be deleted from the Xt2 screen
BASECAMP AND XT2
- Has liked: 183 times
- Been liked: 166 times
Re: BASECAMP AND XT2
I am currently trying to get video evidence of the XT2 or Tread changing the route / ignoring the shaping points. Each time I do it on video, it fails to show the fault. Then I do it without video it shows the fault. Then I do it again without video, it shows a similar fault but in a different place.
I discovered last thing last night that it was something to do with the timing. Probably the random (?) amount of time that it takes to synchronise fully.
Or maybe, and this is definitely my favourite theory, it was my choice of expletives that I uttered in frustration on the penultimate attempt. It needed something that turned the air blue.
Whatever - glad your issue is sorted.
And your post sums up the frustrations when there's so many variables, having variable influences / timing.
The only consistency is it inconsistency!
