Re: Zumo 590 - What the Manuals Do not Tell.
Posted: Fri May 29, 2020 8:49 am
Great explanation
Dedicated forums for Garmin Zumo motorcycle satellite navigation. All questions answered from problems, route planning, touring to tips and tricks
https://mail.zumouserforums.co.uk/
When I do this, despite having about 17 shaping points, I am given a choice of two points- the start and the end. That's it. If I pick the start point I get a dropdown menu with a wrench and an up/down arrow icon. EXACTLY the same thing happens if I pick the destination. There's a green flag next to the start point and a checkered flag next to the destination.
Good point, I found that out too. My power cradle is wired directly to the battery so in this case the gps had been on without power interrupted for about 4 hrs.Iris wrote: ↑Thu May 28, 2020 11:19 pm I do all of my route planning and editing on BaseCamp, not the unit.
Rbentnail, I always check to make sure my gps says ready to navigate before I activate the route. I have learned to wait till the gps has located satellites.
I noticed that if I don’t wait, it will ignore my route a re-calculate even if I have recalculation disabled.
You have to pick the start point otherwise you cancel the rest out but I suspect you know this alreadyrbentnail wrote: ↑Fri May 29, 2020 12:47 pmWhen I do this, despite having about 17 shaping points, I am given a choice of two points- the start and the end. That's it. If I pick the start point I get a dropdown menu with a wrench and an up/down arrow icon. EXACTLY the same thing happens if I pick the destination. There's a green flag next to the start point and a checkered flag next to the destination.
So I pick neither. If I press MAP it shows a preview. If I pick GO! it it then gives me a list of points. I pick the next one I have not reached yet, in this case the start point. It then makes a route different from the preview. As far as I can tell I am NOT picking the destination to route to.
jfheath wrote: ↑Fri May 29, 2020 4:45 pm I'll see if I can reproduce this. Mine is a 590 at the moment. I'll just see what that does on the 590 before I add 5 to it. I'll be back.
In the meantime - in Basecamp, can you take a look at the device transfer options, let us know what they are.
On the PC it is in Edit / Options / Device Transfer.
There are 3 (or 4) check boxes which may be blank or contain a tick. How are they set on yours?
Only the middle box "Always match route to the map on my device when transferring." is ticked.
And - I assume your default mode of transport / activity profile is set as motorcycle in Basecamp. What is the route option set to (faster, shorter, curvy)? No. The device is completely useless to me in the Motorcycling activity. Both the device and Base Camp are set to the Driving activity. Both Base Camp and the device are set to Faster Time.
You can see in this thread viewtopic.php?f=12&t=93 when I asked roughly the same questions. I've been trying for 2 yrs to get this damn thing to simply follow a premade route. The gist of that thread (with no real results, obviously) is that I am doing something wrong.
Also - what version of map do you have on the Zumo. And on the computer. What version of software is loaded onto the Zumo.
Base Camp 4.7.1 with Navigator North America NT 2021.1
On the device is Software Version 4.60 and Map: Full Coverage of North America 2021.10
John
I always have all of those checkboxes unticked on Device Transfer Options in Basecamp. But I tried with always match maps ticked, and it made no difference. I have noticed on a previous occasion that it did make a difference. It forced a recalc on import of the route. I don't have any notes and I don't remember the details.
Its the settings in the Basecamp route that are used - (or just the vehicle and the routing properties.) Usually changing the vehicle type will force a recalculation, but it switches the unit to car as soon as you load the route. Beware of using custom profiles though. The Zumo doesn't know what a custom profile is, so when the Zumo receives it, it makes a decision about which profile to use, And it uses Bike. Which WILL force a recalculation of the route !!
I'll take a good look through that. Thanks.rbentnail wrote: ↑Fri May 29, 2020 9:40 pm You can see in this thread viewtopic.php?f=12&t=93 when I asked roughly the same questions. I've been trying for 2 yrs to get this damn thing to simply follow a premade route. The gist of that thread (with no real results, obviously) is that I am doing something wrong.[/color]
Aha. Now - is that a typo or is it really version 2021.1 on Basecamp and version 2021.10 in the Zumo ??
jfheath wrote: ↑Fri May 29, 2020 11:04 pm Right, I have somehow managed to get myself a 595.
Now you and I know that they are both the same decimal number. But it seems that the Zumo doesn't. Years back there was a similar situation with the numbering of the Zumo map and the Basecamp map. One had a nought on the end, the other didn't. The Zumo saw this as meaning that the maps were not identical, so every single route on import would get recalculated by the Zumo. The difference is that this can take a few minutes per route, as opposed to a few seconds. It remained like this until they brought out the next update.
No, that is not a typo. That is exactly what is shown. xx.1 in Base amp and xx.10 on the zumo via Base Camp. I could not figure out how to look at the device directly and see the software and map versions.
So back to a comment I made further up - how long does it take to import a route ? It should be just a couple of seconds during which time the display will indicate calculating. If it takes longer than that for a route transferred from Basecamp, then that is where we need to look further.
I'm confused about what you are asking me. To IMPORT a route contained on an SD card in the device takes 2 or 3 seconds. Sometime as much as 5 or 6 for really long routes but it has always done this quickly.
I do not use the TRANSFER command in Base Camp. I drag and drop the route to MEMORY CARD/USER MEMORY, i.e., what I believe is the SD card, yes? I have never had any difficulty with importing this way.
If you're happy to stick with this to get it sorted and answer a load of questions, I'm happy to keep working at it. We might have to switch to email at some point.
It's late now, I'll read through your previous topic on the same subject tomorrow.
John
