Speed cam warning
simoncrewe
Has liked: 47 times
Been liked: 38 times
Re: Speed cam warning
Post by simoncrewe »
Northernlanes wrote: Wed Aug 19, 2020 8:36 pm for me PGPSW speed camera databaae works fine on my XT, as it did on my 550 and 396 before it.
I also have free lifetime PGPSW updates having previously supplied the various yellow speed camera icons on their site., because of the XT's higher def screen these are a little small but I've doubled their size in a image editor (unfortunately these aren't on the PGPSW site)
The PGPSW data does not seem to run exactly the same on my XT as it did on my 595. I have installed it in the same manner as I have always done, would you mind if I clarified a couple of issues with you?
Have you installed the database on the SD card?
Is it in the 'Garmin folder?
Have you put in in a separate 'POI' folder?
Many thanks
Simon
Has liked: 378 times
Been liked: 384 times
If on a card it should be in Garmin\POI
simoncrewe
Has liked: 47 times
sussamb wrote: Fri Aug 21, 2020 11:42 am If on a card it should be in Garmin\POI
Should they be 'just' in the poi folder? I think I have them in a sub folder entitled GB Cams.
Vespamarc
Been liked: 14 times
Belgium
Post by Vespamarc »
XIKO29
Portugal
Post by XIKO29 »
Northernlanes wrote:for me PGPSW speed camera databaae works fine on my XT, as it did on my 550 and 396 before it.
Hi,
What size do you recommend?
Thanks
simoncrewe wrote: Sat Aug 22, 2020 10:44 am
I always have mine in the POI folder but they should work in folders within that folder although there are some limitations.
