XT2 turns off and restarts
Pete Martin
Portugal
Re: XT2 turns off and restarts
Post by Pete Martin »
It worked. I had to go back to the previous version, 4.6 and reinstall the latest version and it resolved the problem.
thanks for the suggestions.
Has liked: 361 times
Been liked: 768 times
Sometimes I just get lucky !
Thankyou for trying that, and for the feedback. - I knew that it was possible, but had never done it before, so I had to verify that it would work on mine before suggesting it.
But it is really useful to know that it solved that particular problem. I should have suggested a cold reboot or a restore original settings first - but you mentioned that it happened after a software update, so it seemed to be the way to go.
marcmarc
Poland
Post by marcmarc »
This started happening to me on my recent trip to Bosnia. So in my case its having issues synchronizing GPX tracks, its randomly reboots itself every 30 second to 3 minutes for two days, it shows me tripadvisor bullshit near my destination and shows me my speed, together with incoming speed limits, which I can't turn off.
I'm done, no more Garmin crap in my life, I'm selling this POS.
