I've had my XT2 for almost 2 weeks, mounted on R1250GSA. The XT2 will switch itself off and restart, commonly after 10-15minutes, sometimes immediately after turning on.
Unit was originally getting power from the BMW GPS plug (this worked fine for the Zumo XT) and now power is coming from the Hex Ezcan.
I'm going to do a full reset of the XT2.
I've seen some reports of similar issues on advrider forum.
Is anyone else experiencing this, interested in fixes.
Thanks
Scott
XT2 turns off and restarts
- Site Admin
- Has liked: 409 times
- Been liked: 229 times
Re: XT2 turns off and restarts
Are you using any sort of adapter on the bmw nav prep or have you removed all of that?
- Site Admin
I would be temptep to remove it from the hex ezcan and go directly to the battery and eliminate that
- Site Admin
It might also be worth checking other accesories or accesory plugs as to whether they have power when it does cut out as it maybe the central electronics being overloaded and cutting out
there is never a "disconnected from power" message, before count down to shutting off/restart, like I would normally expect if the XT2 loses power.
It just turns off and then back on.
message from the XT2 retailer yesterday that Garmin are aware of issues with 'rebooting' and are working to fix it with update.
I'm 3hours into bike tear down and new installation of XT2 powered directly from battery via relay, with BMW GPS wire as 'trigger'.
