Page 5 of 6
Re: Introducing TripManager
Posted: Sat Feb 08, 2025 5:44 pm
by Peobody
HarryMJ wrote: ↑Sat Feb 08, 2025 4:57 pm
TripManager is amazing...
Agreed. I have been bugging
@FrankB with every program niggle and behavior change preference that I encounter so this statement made wonder if I have expressed it strongly enough to Frank. I hope I have Frank.
Posted: Sat Feb 08, 2025 6:48 pm
by FrankB
Thank you for that... so TripManager do not like the Danish characters
I will make TripManager love Danish characters!
Posted: Sat Feb 08, 2025 6:50 pm
by FrankB
Peobody wrote: ↑Sat Feb 08, 2025 5:44 pm
Agreed.
These are the replies that make it worthwile for me.
Posted: Sat Feb 08, 2025 7:10 pm
by HarryMJ
FrankB wrote: ↑Sat Feb 08, 2025 6:48 pm
Ha-ha, thank you
I changed the Danish character in TourStart, exported from TourStart, but did still not work, but then removed following
from the line below
Code: Select all
<name><![CDATA[Tur 01 Stevns fyr fra Nivaa]]></name>
..and then it just works when using TripManager to import the route to my XT..
I would say, the problem is TourStart, not TripManager
Brgds. Harry
Posted: Sat Feb 08, 2025 7:41 pm
by FrankB
@HarryMJ
A little background regarding CDATA.
CDATA is needed when the data (in this case the tripname) contains XML characters. Think of < > & or "". LT GT Ampersand Double quote. It is definitely not needed for Danish characters!
On the other hand it is NOT invalid to use CDATA, just unneeded and unexpected. Here is an url that probably explains it better.
http://xml.silmaril.ie/cdata.html
Your remark about being CDATA the culprit and not the "A with circle" is correct. I had hoped that by not using that, Tourstart would not generate the CDATA, that's why I mentioned it.
Now, what's next?
- You say a bug in TourStart. I'm not sure. Even more unsure if they will fix it.
- I did some debugging and I'm quite sure I can fix it in TripManager. That will likely be the fastest. Agree?
Frank
Posted: Sat Feb 08, 2025 9:57 pm
by HarryMJ
Hi Frank
FrankB wrote: ↑Sat Feb 08, 2025 7:41 pm
@HarryMJ
Now, what's next?
Frank
Thank you for the explanation... I think you are right regarding TourStart, it is a 1-2 guys company here in Denmark.
- I agree, you will most likely be faster with a solution
Just let me know if and when you will need some test feedback.
Brgds. Harry
Posted: Sat Feb 08, 2025 10:35 pm
by FrankB
HarryMJ wrote: ↑Sat Feb 08, 2025 9:57 pm
Here you go. Version V1.2.0.123 should fix it.
https://github.com/FrankBijnen/TripManager/releases/
@Peobody
Also excluded way points from stripped routes.
Posted: Sat Feb 08, 2025 10:37 pm
by FrankB
I had a look at the site. Looks 'Scandinavian oriented' to me. Can you use it practically when you're not a 'pro user'? (We from Holland dont like to pay!)
Posted: Sun Feb 09, 2025 12:40 am
by Peobody
@FrankB , is there any reason (recommendation?) to uninstall a previous version before installing a new one?
Posted: Sun Feb 09, 2025 7:52 am
by FrankB
No. Everything gets overwrtten.
