Page 5 of 7
Re: Audio warning issue
Posted: Mon Jun 08, 2020 6:29 pm
by sussamb
Not saying this must explain the difference, but often with Garmin devices different locales have different options
Posted: Tue Jun 09, 2020 4:18 pm
by Tac
I think this problem started with the 2.7 firmware update. I'm sure the change of speed limit alarms could be turned off before the update.
Posted: Tue Jun 09, 2020 9:10 pm
by Hati
Tac wrote: ↑Tue Jun 09, 2020 4:18 pm
Not with Australian maps. The issue was there out of the box, as it came from Garmin.
Posted: Tue Jun 09, 2020 9:24 pm
by Skipper
I have software version 2.7 and as I said in my earlier post it works just fine.
Tested it on the road again today.
Posted: Wed Jun 10, 2020 3:18 pm
by Grispoil
Skipper wrote: ↑Mon Jun 08, 2020 5:06 pm
And I can choose 20 over, 15 over, 10 over, 5 over, at the speed limit or OFF.
Also, choose differently for citytraffic or outside.
Where exactly are you getting these options?
I must have checked all menu items on my XT and I just cannot locate these...
Yvan
Posted: Wed Jun 10, 2020 3:44 pm
by sussamb
Worth repeating what I said above in case folks missed it. It's not unusual for different options to be available depending on which locale is selected, so just because one device has an option it doesn't mean they all do.
Posted: Thu Jun 11, 2020 12:00 am
by rbentnail
sussamb wrote: ↑Wed Jun 10, 2020 3:44 pm
As I found recently, not all apps or options are available all the time depending on what settings are chosen.
Posted: Wed Jun 17, 2020 4:03 pm
by Jefro
I can turn all warnings off, including the speedwarning.
Got my XT last Thursday. And I can choose 20 over, 15 over, 10 over, 5 over, at the speed limit or OFF.
Skipper, can you tell us what menu page these options are listed on? Thanks.
Posted: Thu Jun 18, 2020 2:19 am
by Grispoil
Jefro wrote: ↑Wed Jun 17, 2020 4:03 pm
Also Skipper, I see that you are from Sweden, what maps do you have installed on your XT?
Posted: Thu Jun 18, 2020 8:53 am
by simoncrewe
Grispoil wrote: ↑Wed Jun 10, 2020 3:18 pm
Yvan
Go to settings - Driver assistance - Speeding Alert - Inside the City / Outside the City
