WARNING - Garmin Zumo XT hot-shoe connector weakness
crypkema
Re: WARNING - Garmin Zumo XT hot-shoe connector weakness
Post by crypkema »
Vespamarc wrote: Mon Aug 31, 2020 5:45 pm My idea is, that the connector problems coming from the protection hood. most people push too hard on this. Ans it is mostly the lower connector who gives problems.
I and other people who using a 3D printed protector, don't have any problems with the connector.
I'm not sure what you mean by "protection hood".
And what is this "3D printed protector? That's totally new to me.
Thanks,
Chris
Vespamarc
Been liked: 14 times
Belgium
Post by Vespamarc »
Pic 1 is the rubber protection hood @ powercable, Pic 2 is a 3D printed hood.
Schermafbeelding 2020-09-01 om 08.17.44.png (98.98 KiB) Viewed 4905 times
Schermafbeelding 2020-09-01 om 08.21.37.png (1.13 MiB) Viewed 4905 times
Exurban
Has liked: 5 times
Been liked: 8 times
Post by Exurban »
Are those 3DP covers waterproof? The Z660 cover had a gasket inside to keep the contacts protected.
Vespamarc
Belgium
Post by Vespamarc »
They are waterproof, they click over the holder.
mrmagloo
Been liked: 6 times
Post by mrmagloo »
If you have a 3D printer, here is a free STL
https://www.thingiverse.com/thing:4546658
crypkema
Post by crypkema »
I leave mine on the bike all the time, except when I stop. Having only had it since mid-May, it hasn't even seen much for weather. I'm not sure how much the cover would help to keep the power pins from failing.
My thoughts at this point are to keep using it till the new power cable arrives. If it fails again, I'll sell the Zumo XT and start using a ruggedized smartphone. Having to replace a cable at about $40 each 3-4 months, will get grossly expensive.
Yes, I can connect a USB cable to the back of the unit, but why? And how well would that work in rain?
I sure hope the new power cable will be better...
Chris
mastercore
Has liked: 18 times
Been liked: 5 times
Australia
Post by mastercore »
I have the same thought about the rubber cover. Is does not give good tactile feedback to indicate it is attached, leading to pressing harder than required. Add gloves and this is compounded.
This could easily lead to some of the problems with the pins
Biscuits
Australia
Post by Biscuits »
Have had an XT on my bike for about a week and so far no problems..... but I just read this thread.
No new posts for over a month. Is the pin weakness still a problem?
Vespamarc
Belgium
Post by Vespamarc »
Weakness is not a problem, problem is the standardrubber hood. Most people push to hard and on a wrong way the hood over the connectors. A lot of people here have the external version, and they never had any problems with the connectors.
Been liked: 266 times
Vespamarc wrote: Tue Sep 01, 2020 2:17 pm They are waterproof, they click over the holder.
Where are these available from?
