Zumo XT3 and XT3s are introduced
Francis
Has liked: 13 times
Been liked: 18 times
Czech Republic
Re: Zumo XT3 and XT3s are introduced
Post by Francis »
There is no sound setting in the Tread app on your phone, no setting for how to be notified. There is an option to enable notifications for SMS, emails, social networks (WhatsApp, FB Messenger, ...) but there is no option for HOW the notification should sound.
I see only one option: hack Linux in XT3, penetrate the file system and replace/delete the sound file :-)
BTW I have access to .System turned on (long press in the upper right corner of the sound Mixer), but the sound files are not there. :-(
BMW R1200 ST
I was thinking that, and yes you can block all kinds of notifications -including text messages - it stops the sound, but the message isn't displayed either !
It seems to be generated by the Zumo when Tread sends it any kind of notification.
Francis
Has liked: 13 times
Czech Republic
Post by Francis »
Yes, the soud is played by XT3 (or XT2, Tread 2, ...), and as they wrote to me from support, there is no way to turn it off.
BMW R1200 ST
bogdan
Post by bogdan »
Hello guys,
I bought a new motorcycle and it came with this Garmin Zumo power cradle, but I'm not sure which version.
Am I correct to assume it is the first Zumo XT?
Thank you for your help
turbo19
Has liked: 193 times
Been liked: 47 times
Andorra
Post by turbo19 »
Yes, this is for a Zumo XT ;)
twowheelstom
Has liked: 146 times
Been liked: 54 times
Post by twowheelstom »
bogdan wrote: Mon Mar 23, 2026 9:59 am Hello guys,
since the new XT3 is direct wired to 12 volt battery source, maybe it would be best to remove that XT cradle and install the new XT3 cradle, that's IF you are planning on getting an XT3, just to be safe
Zumo 396
1994 Yamaha 250
