Garmin Zumo 390 TrackLog question - storage limit of device
I have just returned from a 2 week trip and wanted to load up the tracklogs (Where I've been) information into Basecamp. It looks like only the last 3 days are available. On investigation it appears to be a memory issue. It also looks like it is not possible to extend the memory for the tracklogs using an SD card. I can put the routes and waypoints stored into the card, but to use them I would have to reload them into memory anyway. Am I stuck or does anybody have a suggestion. I have searched extensively but can't find any information, and I can't be the first one to come across this issue. Thanks
Re: Garmin Zumo 390 TrackLog question - storage limit of device
You're a star.
I found the archive file in windows file explorer and imported them into BaseCamp.
Garmin must archive when it runs out of space. The final three days came in to Basecamp fine.
Problem solved.
Thanks again.
Problem solved.
Thanks again.
