XT mount accidentally unlocking during ride
SteveA
Has liked: 22 times
Been liked: 3 times
Post by SteveA »
This hasn't happened to me yet but each time I ride with the XT in the mount I'm getting 'undue anxiety'.
If the XT was to pop out of the mount it would probably be destroyed or ran over by a following vehicle etc.
Has anyone a simple solution to prevent this happening or am I maybe worried about something that won't happen?
Hati
Been liked: 15 times
Australia
Re: XT mount accidentally unlocking during ride
Post by Hati »
I can see how that idea may cause undue anxiety, but other than one or two reports about the first release mount supposedly loosing the XT, no one has complained of this happening.
When I click mine in, I try to pull it away from the mount to check. No issues. There is apparently a rubber web that can be added to the mounted XT, but I never saw the need to get it.
Andrew_XT
Italy
Post by Andrew_XT »
Me for example i have bought the cover case.
In the cover case corner there is an hole were i instaqlled a string and fixed it on the mptorcycle.
SteveA
Has liked: 22 times
Been liked: 3 times
Post by SteveA »
Andrew_XT wrote: Sat Feb 06, 2021 11:49 am Me for example i have bought the cover case.
Have you more details please?
SteveA
Has liked: 22 times
Been liked: 3 times
Post by SteveA »
Hati wrote: Fri Feb 05, 2021 8:18 pm I can see how that idea may cause undue anxiety, but other than one or two reports about the first release mount supposedly loosing the XT, no one has complained of this happening.
Thanks. I do worry about the long term implications of having to remove the XT from my motorcycle every time I'm not close to it. Wear on the plastic lips that hold it to the mount etc.
Exurban
Has liked: 5 times
Been liked: 8 times
Post by Exurban »
I think Ram Mount- “Ram Tether” around $4 USD is the spiderweb rubber thing mentioned above that works to hold it. Someone posted on this forum or maybe elsewhere. Others epoxy a clip used for running zip ties then attaching a tether. I have neither and while not actual off-road, I’ve been on some rough unpaved roads without issue. I could understand the long term effects though. I remove mine just about whenever I get off the bike.
Skipper
Sweden
Post by Skipper »
I can recommend the Zumo Lock for the XT, I have used it since I bought the XT as soon as it became available.
Check it out on ZumoLock.com
TeqTrade
Schapendijk 31/A
7467 PN Notter (Wierden)
NEDERLAND / NETHERLANDS
Email: sales@zumolock.com
Tel: +31 (0)88 - 0226 999
Kamer van Koophandel VEL nr. 08142980
BTW−nr. NL 8152.62.085
2010 Vulcan 1700 CT (Nomad)
RV Kabe Travelmaster 880 LT Royal
Andrew_XT
Italy
Post by Andrew_XT »
SteveA wrote: Sat Feb 06, 2021 11:51 am
Sorry, i don't understand how to upload image
colirv
Has liked: 66 times
Been liked: 64 times
Post by colirv »
Click "Post reply" then click "Attachments" tab at bottom. You can then drag an image into your message box.
Colin
BMW R1250RS
https://www.namrider.com
Andrew_XT
Italy
Post by Andrew_XT »
colirv wrote: Mon Feb 08, 2021 9:58 am Click "Post reply" then click "Attachments" tab at bottom. You can then drag an image into your message box.
