Ver 7.3.1.0 Released
As the title says.
GE 7310.JPG (18.82 KiB) Viewed 4919 times
colirv
Has liked: 66 times
Been liked: 64 times
Re: Ver 7.3.1.0 Released
Post by colirv »
Is this the one that won't allow you to save maps on your computer?
Colin
BMW R1250RS
https://www.namrider.com
colirv wrote: Sat Mar 13, 2021 10:00 am Is this the one that won't allow you to save maps on your computer?
Nasty rumor?
colirv
Has liked: 66 times
Post by colirv »
From other forum it seems that XT users have found that upgrading to the latest firmware means that Garmin Express is updated to the latest version and there is no longer the option to save maps to the computer as well as to the XT. This has been observed for both 7.3.1.0 and 7.4.0.0. I imagine it will need observations from other users to show if this problem is unique to the XT.
Colin
BMW R1250RS
MSTOCK27370
Has liked: 22 times
Been liked: 44 times
Post by MSTOCK27370 »
colirv wrote: Sun Mar 14, 2021 9:59 am From other forum it seems that XT users have found that upgrading to the latest firmware means that Garmin Express is updated to the latest version and there is no longer the option to save maps to the computer as well as to the XT. This has been observed for both 7.3.1.0 and 7.4.0.0. I imagine it will need observations from other users to show if this problem is unique to the XT.
I have checked Express version 7.3.1.0 and updated to version 7.4.0.0. Using either version, the option to load maps to the computer is still available. This issue appears to be unique to the Zumo XT with the newest firmware. There is some interaction between the XT and Express, so that Express no longer shows that option when it sees an XT. I have tested this on a Nuvi 54, Zumo 450, 550 and 590. They all worked.
Michael S.
Trinity, North Carolina
colirv
Has liked: 66 times
Post by colirv »
I wish now I'd hung on to the 595!
Colin
BMW R1250RS
mzeist
Has liked: 33 times
Been liked: 31 times
Post by mzeist »
as long as your 595 is listed in Express you can still install maps to your pc..
Groet, Marcel.
colirv
Has liked: 66 times
Post by colirv »
Thanks. I shall try that the next time there's a new map update.
Colin
BMW R1250RS
mzeist
Has liked: 33 times
Post by mzeist »
as will I ;-)
Groet, Marcel.
