BASECAMP + OSX 10.11 + ZUMO XT = CRASH
Hi, I have a Mac with SO El Captain and a Zumo XT. I downloaded from Garmin site Basecamp version 4.7.0, cause a software bug as soon as the navi is connected to the Mac, the system crashed. I found Basecamp version 4.8.3 but this also has a USB bug and does not recognize the Zumo. Maybe someone can help me and have a later version, as 4.8.4 or 4.8.6 or another that support osx 10.11? Thanx
- Has liked: 148 times
- Been liked: 139 times
Re: BASECAMP + OSX 10.11 + ZUMO XT = CRASH
Garmin stopped supporting OS 10.11 as of BC 4.8:
Changes made from version 4.7.0 to 4.8.3:
Upgraded app to 64-bit.
Dropped support for Mac OS 10.10, 10.11 and 10.12.
Fixed issue where certain poi files would use large amounts of memory.
bicyclenut
- Has liked: 1 time
- Been liked: 3 times
Make sure Garmin Express is not running in background or at all or Basecamp will not recognize it. Also no other App that would connect to XT. I use Android File Transfer App to connect direct to XT and inserted SD Card and I need to make sure it is turned off.
This morning I was having issues getting Basecamp to see the XT and I restarted my Mac and the XT to get it to resolve.
Zumo XT2
Zumo XT
BMW NAV 5
Navigating my BMW R1200RT
Zumo XT
BMW NAV 5
basecamp 4.8.3 runs on osx 10.11, it is now installed on my macbook. I called Garmin customer service: they replied me that these are bugs they know and would let me know how to fix it but I have heard noone.
