Google Earth - all options not working
JohnnyRidesAlone
Been liked: 10 times
Post by JohnnyRidesAlone »
So following the knobling of Basecamp’s “view in Google earth feature” by the spy master general, they then disable the ability to look at street level in Google Earth Desktop. Google Earth online just keeps crashing and Google Earth Pro wants an update that will not run.
What I am trying to do is look at my Basecamp routes at a street level to check if my chosen route is a street or a track. Any pointers?
Machine is fairly new and powerful and I use Firefox on the “worst of all evils” principle
Has liked: 109 times
Been liked: 252 times
Re: Google Earth - all options not working
I've found that Google Earth Pro works flawlessly as long as, like much else, Garmin is not involved with it. I simply open Earth as a separate tab by double clicking a destop icon.
Win10, Firfox, Google Earth Pro ver. 7.3.3.7786 (32-bit)
Has liked: 372 times
Been liked: 383 times
I save my routes from BaseCamp as a kml file and then open them with GE Pro, works perfectly
JohnnyRidesAlone
Thanks Russ, I open from a browser and run for 90-120 seconds and lock up. Wonder if it is ad blocker
JohnnyRidesAlone
Some kind of resolution. Adopting "do the same thing and get a different result" which is unique to IT, I managed to download Google Pro. It now appears to give me street view when I want and I can upload my KML routes. Google online is out of my bookmarks now. It appeared to be some kind of graphic issue and said the site was "experimental"
So all working now for a couple of months until Big G decides they are not making enough and change it. Thanks for your help
