Focus XT - Software Update Log
There doesn't seem to be an official log, so I have constructed this unofficial version from screenshots.
The versions that I think that I remember are:
2.30*, 2.50*, 2.60*, 2.70, 2.80, 2.90, 5.90, 6.10*, 6.20, 6.30, 6.40, 6.50
I don't have screenshots of the following versions - 2.30, 2.50, 2.60, 6.10
Revision 270 - 13 May 2020.jpg (33.1 KiB) Viewed 4679 times
Revision 280 - 9 July 2020.jpg (17.79 KiB) Viewed 4679 times
Revision 290 - 5 Aug 2020 From post by vespamarc.jpg (15.52 KiB) Viewed 4173 times
Revision 590 - 10 March 2021.jpg (56.78 KiB) Viewed 4679 times
Revision 620 - 12 May 2021.jpg (47.73 KiB) Viewed 4679 times
Revision 630 - 24 September 2021.jpg (29.75 KiB) Viewed 4043 times
Revision 640 - 16 April 2022.jpg (15.69 KiB) Viewed 3220 times
Revision 650 - 18 May 2022.jpg (12.68 KiB) Viewed 3048 times
Revision 660 - 13 October 2023.jpg (22.66 KiB) Viewed 1733 times
Re: XT Firmware Update Log
Normally I would simply add an update to the first post - and will continue to do that when new updates appear.
Also, for this post I have the heading 'Firmware Update'. Strictly speaking this is incorrect - but many people use this term, so a search using the tem 'Firmware' would find this page. I have never seen Garmin issue a Firmware update, although different ages of XT do have different Firmware Versions (eg for Bluetooth and GPS).
These pages refer to the System Software Updates - which is how Express and the Zumo Screen correctly describes them.
But - I have just had my Zumo XT replaced. I guess that the refurbished unit that I received was prepared and set up sometime between v6.20 of the software and v6.30 - as it has come with 6.20 installed. So these screen shots would be out of sequence in the software update log above.
Below are screen shots of the updates that Express thinks are necessary now (10 Dec 2021) for a unit prepared before v6.30 was released - ie probably sometime beetween May and Sept 2021. I won't be updating this XT to v6.30 for a while - since 6.30 states that it improved the handling of shaping points, and yet it didn't address the issues that I had reported with Shaping Points over a year ago.
My original unit was purchased in April 2020 - one of the first of the second batch to arrive in the UK. It had v6 of the hardware. The serial number of this refurbished unit suggests it may have come from the same batch - but it has been provided with v8 of the hardware. So that may be a significant refurb. I'll report if I spot any improved behaviour.
(I have altered the Unit ID and the MAC address on the screen shots below.)
Version Censored.png (43.34 KiB) Viewed 3785 times
Refurb XT Updates 1.png (80.77 KiB) Viewed 3785 times
Refurb XT Updates 2.png (64.33 KiB) Viewed 3785 times
Last bumped by jfheath on Fri Oct 13, 2023 9:32 am.
