Route import and convert
Kramer
Denmark
Post by Kramer »
Hi there :)
i hope someone is able to help with this issue ??
when i import a gpx route in the 595 i get it in "tracks" .. no problem with that .. i covert it to a route and wait ....
then the problem accours ? i always choses fastest,shortest etc .. and change the original route ... is it not possible to just import a route and drive it ?
the routes is for adventure motorbike and i get it from the TET site.. the are routes made for offroad track all over the world , but when i want to drive it always calculate the route :oops:
i can chose tracks and show on map ,but the line is so small and hard to see , and i have to possibility to change color but not make the line bigger
HELP
Has liked: 104 times
Been liked: 221 times
Re: Route import and convert
What I do:
I import the .gpx file NOT to the 595 but rather to Base Camp. Most show up as a track which I use Base Camp to convert to a route and edit it as I wish it to be. I then transfer that route to the 595, import it and ride it.
Kramer
Denmark
Post by Kramer »
So you just import route and not track to the 595?
And it os ready to ride without the gps calculations..
I will try tomorrow and see if it works..
I was wondering why it’s not possible on the zumo when it is on the Montana and other gps.. even the Garmin for mountain bike gps ….
Thanks a lot 🙏🏻
Correct, I import a route to the zumo from base camp, not a track. Most .gpx files i see are tracks and to me it much easier to convert and edit in base camp than it is on the zumo.
