Easy solution to install City Navigator maps on PC/Mac
Rofor
Has liked: 170 times
Been liked: 75 times
Austria
Post by Rofor »
Ok guys - quick, simple and easy-to-do hack to install maps for the Garmin Zumo XT also on PC/Mac, even when already updated to a firmware >v2.90:
All you need is a sd card or an usb-stick:
  • Copy the file 'GarminDevice.xml' from the Zumo XT (found in the folder /Garmin/) to the sd card or the usb-stick in a folder 'Garmin'
    Disconnect the Garmin Zumo XT
    Open the file on the sd card or the usb-stick with an editor and search for the entry '<Name>PreProgrammedNamedMaps</Name>' - should be around line 140
    Delete the part 'Named' of the file, should be '<Name>PreProgrammedMaps</Name>' now
    Save the file
    Safely pull the sd card or the usb-stick and connect it again
    Start Garmin Express, should now show the Garmin Zumo XT as 'connected'
    Click on the Zumo XT
    Click on 'Map details'
    Click on 'Map options' of the City Navigator Maps
    There should be an option to 'Install Maps on the Computer'
Please DO NOT edit the file directly on the Zumo XT, this could have unknown consequences with further updates!
This is not(!) my finding - the user 'mario_b' in the german 'Naviboard' has found this 'hack' with a lot of 'trial-and-error' steps, all kudos for finding this goes to him! I'm posting this solution for our 'cant-install-maps' problem with his permission!
If you understand german - here's the original thread at 'NaviBoard' - https://www.naviboard.de/thread/66134-k ... post531835
Bye, Robert :)
communicator
Been liked: 6 times
France
Re: Easy solution to install City Navigator maps on PC/Mac
Post by communicator »
EXCELLENT !!! :D
I followed the procedure and :
1) The USb key was seen as my Garmin Zumo XT
2) I was able to access the installation procedure of the 2021.30 map on my PC
3) The installation of this map went perfectly.
Thank you! Thank you! Thank you and congratulations for finding this clever solution
On s'en fout de connaitre la vérité, l'essentiel c'est d'avoir raison (Me Eric Dupond-Moretti)
It doesn't matter what the truth is, the important thing is to be right (French Lawyer Eric Dupond-Moretti
Fun is not a straight line !!!!
Has liked: 424 times
Been liked: 241 times
Thanks
I have made it sticky so it keeps at the top :D
Followed the instruction and it works as it should 8-)
Thanks for posting this
groundhog719
Has liked: 12 times
Been liked: 5 times
Post by groundhog719 »
Great, thanks!! Too bad Garmin made this work-around necessary.
ConiKost
Been liked: 7 times
Post by ConiKost »
Not needed any more.
See viewtopic.php?f=18&t=1255
Milu23771
Been liked: 8 times
Italy
Post by Milu23771 »
Thank you, It work very well.
JohnnyRidesAlone
Been liked: 10 times
Post by JohnnyRidesAlone »
Email from Garmin today
We have now released Garmin Express version 7.6.0 for Windows and Mac which will allow you to once again install your maps to the computer.
For help with updating Garmin Express, see: Updating the Garmin Express Application Software
Thanks for your patience while we looked into this issue.
Rofor
Austria
Post by Rofor »
Hi all - please DO NOT 'throw away' your 'fake' Zumo XT, if you already made one!
Garmin has done it again and screwed the Garmin Express update 7.6.0.0. - you're able to install the maps again on a computer, BUT(!!) the unlock file isn't copied along and so the map stays locked in BaseCamp and you can't use it!
Many users still had verified this new bug and so you should still use your 'fake' Zumo XT (as described in post 1) as long as Garmin corrects this new bug in Garmin Express...
Bye, Robert :)
simoncrewe
Has liked: 47 times
Been liked: 38 times
Post by simoncrewe »
JohnnyRidesAlone wrote: Fri May 28, 2021 1:10 pm Email from Garmin today
As 'Rofo' points out GE 7.6 does not work! I have a case open with Garmin UK to resolve the issue.
I find it so frustrating that Garmin regularly releases such 'Buggy' software.
