Hi all, I have recently purchased the Zumo XT for use on my Kawasaki Ninja 1000SX for trips. I have set up the unit and updated and had it out for a test ride. NOT GOOD. Do not think I will be keeping this long and will probably sell at a great loss. You would think at the price point of this even the basic things would work as expected, or am I just being too critical.
Regards,
Martin H
Hi from Cumbria, UK
Re: Hi from Cumbria, UK
Thanks, I will put up a post at a later date once I can say for certain what is happening. I think most of the problems are software related and when you try and follow someones advice and direction it turns out that that my unit cannot do it. Biggest problem I am having at the moment is mapping and the routes it plans.
- Site Admin
- Has liked: 424 times
- Been liked: 243 times
Hi @mhirst121 welcome to the forum
I would start a new thread as you have said with all your issues you are having and I am sure someone will help you out
It might just be a case of a wrong setting somewhere
