no possibility to use this gpx file to go to Morroco
Tsphax
France
Post by Tsphax »
Hello team,
I've got a Zumo XT and it's ok for the update. I transfert the file via Garmin Drive application, but when I would like to see the trace, I can't if someone can test it and say me why my gpx file can't be used on my Zumo... I just see 1400km of the 5000...
Thank you :-)
Christophe
maroc.gpx
(1.68 MiB) Downloaded 406 times
Has liked: 382 times
Been liked: 384 times
Re: no possibility to use this gpx file to go to Morroco
Can't test it but pretty sure it's to do with the length of the track as there is a limit to the number of points you can have in a track. You'll need to split it into shorter lengths, BassCamp will allow you to do that.
Tsphax
France
Post by Tsphax »
So, If I would like to have this trace with all points I've got, I must "cut" this trace by 3 or 4, that's it?
Regards.
Christophe
Or remove some points ...
