Not routing properly with OSM Street maps
Triplog
Has liked: 19 times
Been liked: 3 times
Post by Triplog »
Has anyone found that the XT will not route properly with OSM Street Maps?
When I activate these maps I lose Distance to Next Turn and Speed Limits. If the route includes a Waypoint I can't get past that! The unit keeps trying to route back to that point, even trying to skip the waypoint leads to odd random routing.
Has liked: 344 times
Been liked: 368 times
Re: Not routing properly with OSM Street maps
Probably the map, some OSM maps cause issues.
Hardly any I use for example include speed limits, if you use OSM maps you can't expect them to work exactly like Garmin maps
Rofor
Has liked: 154 times
Been liked: 67 times
Austria
Post by Rofor »
Hmm, first question for problems with 3rt party maps - did you disable the original City Navigator street maps under 'MyMaps' on the Zumo XT?
Two routeable maps activated at the same time makes for sure troubles...
Bye, Robert :)
Very true. I wondered once why my Garmin map wasn't working normally then found a recent software update had enabled an OSM map I also had loaded :roll:
Triplog
Has liked: 19 times
Been liked: 3 times
Post by Triplog »
Thanks for the replies. Yes I'd tried disabling the CN standard maps - no difference. Seems to be as Sussamb suggested - third party maps just throw wobbles! From now on I'll stick to the standard maps when routing through anywhere new and use topo maps when just bimbling about! Every day's a schoolday!
