Garmin Express 7.6.0.0
carolinarider09
Has liked: 34 times
Been liked: 40 times
Post by carolinarider09 »
Garmin Express 7.6.0.0 is available for Mac. Just installed. Have not used it.
ray6576
Been liked: 9 times
Re: Garmin Express 7.6.0.0
Post by ray6576 »
I have installed and used it to update the maps on my Mac for basecamp. I did not have any issues.
Fatboy96ci
Post by Fatboy96ci »
Hi, I am still not able to make local copies. This version at least has the option to make local copies off the maps to use in Basecamp, but I can't get it to work.
Foto 13-06-2021 om 14.24.jpg (48.42 KiB) Viewed 7971 times
Is this what you guys see when you copy maps local to use in Basecamp? I can not select a destination of the maps. So where are they?
Thanks for the help,
Regards,
Jos
