Garmin Zumo XT
- Been liked: 1 time
Garmin Zumo XT
I am looking at the Garmin Zumo XT as a possible GPS for a 2020 GS. Does anyone have experience wiring and mounting this unit?
- simoncrewe
- Has liked: 46 times
- Been liked: 37 times
Re: Garmin Zumo XT
The XT comes with Ram mount fittings & the base is drilled to the normal 'AMPS' standard - so it is basically up to you as to how you mounts it. The ram mounts are a bit 'clunky', I went for the Touratech mount on my KTM.GeorgeSteven wrote: ↑Fri Jun 04, 2021 8:39 am I am looking at the Garmin Zumo XT as a possible GPS for a 2020 GS. Does anyone have experience wiring and mounting this unit?
The wiring on the XT is very simple & compact, with just a positive & ground connection needed. I think I am correct in saying that the BMW's come with a dedicated GPS / can bus supply at the front of the bike near the headstock. You can buy the correct adapter plug from the dealer.
