Lost Folders
titter
Has liked: 8 times
Lost Folders
Post by titter »
I've reinstalled basecamp on my PC and all the folders and routes which would show in my library in the old version have gone. Theres lots of files sitting on my PC in Garmin folders, would any of these be the old folders and routes? I'm thinking files with extensions GMP.
Will this library be stored on my PC anywhere and if so what are the files extensions I need to look for?
colirv
Has liked: 54 times
Been liked: 43 times
Re: Lost Folders
Post by colirv »
I think .gmp files are the maps. My Basecamp data seems to use .gdp files. FWIW I find Everything priceless for finding stuff on a PC!
Colin
BMW R1250RS
https://www.namrider.com
MSTOCK27370
Has liked: 13 times
Been liked: 33 times
Re: Lost Folders
Post by MSTOCK27370 »
titter wrote: Thu Jun 10, 2021 7:51 pm I've reinstalled basecamp on my PC and all the folders and routes which would show in my library in the old version have gone. .......................
On a Windows PC, all of the routes and folders should be in the BaseCamp database.
It should be in C:\Users\your-username\AppData\Roaming\GARMIN\BaseCamp\Database
At least, that where it is on my PC.
Michael S.
Trinity, North Carolina
Has liked: 344 times
Been liked: 368 times
Re: Lost Folders
Your data is in alldata.gdb
If you search for that file you'll find the folder you need to point BaseCamp at.
alan sh
Has liked: 6 times
Been liked: 26 times
Re: Lost Folders
Post by alan sh »
sussamb wrote: Thu Jun 10, 2021 9:43 pm Your data is in alldata.gdb
But if you have re-installed BC, won't it overwrite the files unless you have moved them beforehand?
Alan
Re: Lost Folders
No
