New Member
CaptainBillK
New Member
Post by CaptainBillK »
Greetings! Just found you guys... thankfully!
I've been using Garmins for a long time. Started with a Zumo 550 when they first came out, now have a XT and a Nav V. Sadly, my Nav V is having issues. I was loading routes/waypoints to both systems, but did the XT first. Then, when I tried to load a route to the Nav V, it said it was full. There's not other routes on it. I did a factory reset and when I look at the "drive" on my Mac it says "Capacity: 7.56GB, Available: 348.6MB (348.5 purgeable), and Used: 7.56GB." I'm not sure how that happened, but was thinking that the maps from the XT might've tried to load onto the Nav V - but it only shows "City Navigator North American NT 2022.1".
Hope you have some ideas about what happened or what I can do. Also, thanks for allowing me to join. Appreciate it!
Bill
The woods are lovely, dark and deep,
But I have promises to keep,
And miles to go before I sleep...
2019 Harley FLHTK, 2015 BMW R1200GS, 1982 Kawasaki KZ550, 1971 Norton Commando 750, 1958 Harley FL
Has liked: 381 times
Been liked: 384 times
Re: New Member
One issue with a Mac is the trash, is that empty?
CaptainBillK
Re: New Member
The trash is empty.
