Change Current Track Color
- Has liked: 1 time
- Been liked: 1 time
How do I change the color of the current track (ie the track started with the track recorder)?? I've read the threads on the style file, & changing the color for MAP_TRK_CLR. This changes the history track (the one that shows when you select 'Travel History' under 'Map Layers' ), & it changes the thickness, but doesn't change the color of the current track log. I tried changing MAP_RTE_ACTV_LEG_CLR and MAP_TRK_SAVED_CLR too, but they don't change the current track. Anybody?
