I get a message:
“Install BaseCamp.pkg” can’t be opened because Apple cannot check it for malicious software.
Any workarounds or is a software update required?
Thanks,
Can't install Basecamp 4.8.6 on Mac with Catalina
- Been liked: 1 time
Re: Can't install Basecamp 4.8.6 on Mac with Catalina
I believe you’ll want to use the “Open Anyway” button in Security and Privacy Settings. See https://support.apple.com/en-us/HT202491
Good luck!
Good luck!
