Is there a way to lock the Toolbar in BaseCamp? When I open to plan a route, the Toolbar is often changed or moved around (i.e. not the way I set it up). It's driving my OCD crazy! Searched but found no answer...
PS> many thanks to all as I have gotten fairly used to BaseCamp, now I find it useful in planning routes. Keeping the XT and the TomTom will be backup.
"Locking" Toolbar
Re: "Locking" Toolbar
I am on Windows 10 / Laptop. I reviewed Options an apparently this has been a "feature request" to Garmin for a time.
- Has liked: 427 times
- Been liked: 934 times
Mine usually stays as it is, but if I change screen resolution, or shift it to the other screen (I have 2), then it can get confused. Ditto if the PC gets turned off without shutting down.
If I change mine, it stays exactly as I have changed it.
Screen resolution does mess it up a bit though - because it keeps the sttings that it had when I last used it - so one computer can change it for the other computer when you use that.
This may work if your version of windows and your account permits it. Sometimes the normal user account doesn't allow the computer to make the changes that the program needs it to.
So it may be possible that it (Basecamp) has never been setup with any settings. Try running Basecamp as administrator, make some changes and exit. Then load it again - see if it keeps those changes.
To run a program as administrator in Windows 10:
To do that, do the same as above, but instead of clicking 'Run as Administrator':
- Click the windows icon bottom left.
- Start Typing 'Basecamp' - after a few letters, the Basecamp program should appear in the list.
- Right click on Basecamp and select Run as Administrator.
- Select Open File location.
- Right click on Basecamp in the folder contents that is dsiplayed, and select 'Create a Shortcut'. Put it on the desktop.
- Find the Basecamp shortcut icon on the desktop, Right click it and select 'Properties'. Click the advanced button.
- Click the checkbox - Run as Administrator.
