Replace basecamp maps after unit replacement?
Sightseer99
Been liked: 3 times
Post by Sightseer99 »
So my Zumo XT was replaced under warranty; now I have a new unit and the old unit was returned.
Does this mean I need to delete/reinstall the City Navigator North America NT 2022.2 map in BaseCamp?
Thanks for any advice.
Has liked: 372 times
Been liked: 383 times
Re: Replace basecamp maps after unit replacement?
No need as that isn't affected, but check the map and software on your XT is up to date by running Express.
I see you mention the NA map, was this an additional map you purchased? Did Garmin allow you to reinstall that map on your new XT?
Sightseer99
Been liked: 3 times
I corrected the flag in my profile. This unit was purchased for the U.S. market; it was shipped with NA maps.
I did update the firmware and maps on the unit with GE. Thanks.
In that case you should be good to go. Just check you have the same map version on your Zumo and PC.
