FYI the default board style is going to be changing from SE Square Left to Prosilver Special Edition this is due to the fact that there is a number of updates that have been pending for sometime now that I have been putting off due to no updates for the SE Square Left Style! I was hoping that this style would be brought up to date but sadly not.
As a Result I will be uninstalling the SE Square Left style so if you are using this style can I encourage you to please change it to one of the other installed styles which are either Prosilver Special Edition or Prosilver.
You can do so via your user control panel or via the drop down list on the top right of the navigation bar where it says "Style"
Once I do update all the software and remove the SE Square Left style then the default style will change anyway.
Thanks
Board styles
- Site Admin
- Has liked: 438 times
- Been liked: 265 times
Re: Board styles
I have updated the styles and changed the default one and now removed the unsupported style
On top of this I have updated the forum software and all plugins
If anyone see's any issues please let me know
