Navigator V Combining multiple Trips into one
Having problems with your BMW navigator 5? then please post here with any sat nav, software, mount or cradle problems.
lgresh
Portugal
Post by lgresh »
Has anyone found a way to combine multiple trips into a single one and do so directly on the unit without hooking into a PC and using BaseCamp or TYRE or whatever?
Example: you ride very nice roads. At the end of the day you convert your multiple tracks into multiple trips. You now want to combine these into a single trip... Thanks
Has liked: 380 times
Been liked: 384 times
Re: Navigator V Combining multiple Trips into one
Can't think of any unit that can do that.
