I just ordered a Zumo 396 and I downloaded the manual, however I don't see anything in there that speaks to the number of MP3's you can load on the device. I believe with my Zumo 550, the limit was 700. Anybody know the limit on the 396?
I am aware that the files should be placed in folders, and I'm OK with that, I just need to know how many MP3's it will support. I will be adding a 32Gb card to the 396 once it arrives and plan on putting the music on that.
Thanks for any and all help;
Gord
Zumo 396 and MP3's
- Has liked: 110 times
- Been liked: 254 times
Re: Zumo 396 and MP3's
Have no idea about the 396 but my relatively new 595 has 3013 music files in 247 folders on a 64gb SD micro card. There's no difference in boot time with or without the card inserted and it (so far) plays music just fine.
ETA: some excellent success on pg 2 -> viewtopic.php?f=8&t=48
- Sleuth
- Has liked: 14 times
- Been liked: 16 times
Good evening,
I knew that there used to be a Garmin page which gave the number of MP3 files that various devices could hold.
Here is the page: https://support.garmin.com/en-US/?faq=L ... =noProduct
Although it only lists the 395 & 595, I assume that the number will not be change drastically.
It certainly would explain why the number of songs I use (1400) worked on the BMW Nav IV - 660 rebadged, and it crashes on the 396.
Best regards
Sleuth
Best regards
Sleuth
Maps: Europe NTU 2024.10
