Maps not visible on screen
Skipper
Sweden
Post by Skipper »
When I turned on my XT, there was no map on the XT.
Tried reloading the maps in Garmin Express and it started but after a short while I got an error message and
nothing more happened.
When I check in the menu it says that CN Europe NTU North and South is installed.
When I try to plan a trip it seems to work as it should but there is nothing visible on the screen.
Is a master reset necessary (done how?) or does anyone recognize the problem.
Hate to loose all I have on the unit.
2010 Vulcan 1700 CT (Nomad)
RV Kabe Travelmaster 880 LT Royal
Has liked: 381 times
Been liked: 384 times
Re: Maps not visible on screen
Are the 2 maps checked?
Skipper
Sweden
Post by Skipper »
Yes, they are,
On my first try to reload the maps I got en error message but the second time it did reload the maps but no difference.
raza
Has liked: 7 times
Been liked: 7 times
Slovenia
Post by raza »
Do you have a backup of previous maps? Replace new files with those in the repository.
or
Try deleting all maps update files manually and then reinstalling the maps using GarminExpress.
raza
Has liked: 7 times
Been liked: 7 times
Slovenia
Post by raza »
Frst remow SD kart end tray!
Skipper
Sweden
Post by Skipper »
A master reset took care of the problem.
