Route overlaps Track
level
Spain
Post by level »
Hello everyone, I just bought an xt juice. I have a problem, to see if someone can help me.
The thing is that when you see a track on the map, and put the route of that track, the route is superimposed on top of the track, preventing its visibility.
On my old 595 it was upside down, so I could see my route and my track at the same time. Does anyone know if this is possible on the XT?
auke54
Has liked: 5 times
Re: Route overlaps Track
Post by auke54 »
Hi Level,
I know, this was indeed the other way around. But no problem, just thicken the track and it will peep from under the route line.
so on the XT: Main->Apps->Tracks->Choose Track->Wrench->TrackWidth
jut play with the size to find a suitable one for you.
Have a nice day!
XT (SystemSoftware 6.30)
quinque
France
Post by quinque »
Hello,
To view both the route and the track,
you must also modify the lines of the xxx.KMTF file
like this
level
Spain
Post by level »
thank you
level
Spain
Post by level »
quinque wrote: Tue Feb 08, 2022 4:54 pm Hello,
like this
do you do it with javawa?
quinque
France
Post by quinque »
Hello,
I used the text editor "Notepad++"
(see the tutorials on modifying .KMTF files)
JS_racer
Has liked: 11 times
Post by JS_racer »
like this
nice, it use to display say below your tracking arrow, so a glance could see if you were on the roads desired. that seemed to change mid/late last year.
thanks for this, looks nice, and a good solution
