Zumo 660
shambells
Australia
Zumo 660
Post by shambells »
Hi all i have a bit of a problem, yesterday I turned on my zumo 660 and it wanted to do a update so hooking it to the computer and opened up garmin express to do a update. After it finished turn the zumo 660 back on and all was on the screen was system software missing. Now the computer dosnt recognise it now rang garmin Australia and they said it was to old, so many people have had the same time but i can't find away to reinstall the software. Please help
Has liked: 381 times
Been liked: 384 times
Re: Zumo 660
Is it still recognised by your PC and Express? If so try a reinstall of the software. You've posted this in the Map Updates forum, I'll move it to the correct one.
shambells
Australia
Re: Zumo 660
Post by shambells »
No it's not recognise
Re: Zumo 660
Have you tried a master reset?
shambells
Australia
Re: Zumo 660
Post by shambells »
No how do you do that
Re: Zumo 660
kernowing
Has liked: 134 times
Been liked: 61 times
Re: Zumo 660
Post by kernowing »
shambells wrote: Wed Feb 09, 2022 11:20 pm No how do you do that
Be sure and do a backup before doing a master reset.
2007 GL1800 Goldwing
Zumo 660LM
shambells
Australia
Re: Zumo 660
Post by shambells »
I have tried nothing happened
Re: Zumo 660
Sounds like it may be bricked then :(
shambells
Australia
Re: Zumo 660
Post by shambells »
Thank you for the help
