Does anyone know if the XT has a safety cut off feature in that if you apply too much power it auto shuts off to protect itself or will it be a case of if you apply too much voltage the XT will be toast?
I don't want to try it for obvious reasons
Power overload cut off
- Has liked: 350 times
- Been liked: 747 times
Re: Power overload cut off
I don't know, but I suspect not since the manual refers to replacing the in-line fuse - using a new fast blow fuse. If it had in-built circuit protection, I don't think that a fast-blow fuse would be necessary.
I did read a post (viewtopic.php?p=4755#p4755)
Apparently the user was running the XT via 12v and the only problem was the battery wouldn't charge.
I wouldn't try it just incase.
- Site Admin
- Has liked: 410 times
- Been liked: 229 times
I have searched high and low and can't find a definitive answer!
I have an adaptor on my R1200rt with a step down transformer and it always worries me that it goes wrong and applies 12v to the XT!
The XT works and charges when connected to USB and USB is 5VDC so therefore the XT must require 5VDC. I imagine that there is likely to be a step down transformer (electronic type) within the XT or the XT mount to step the 12VDC from a motorcycle or car to 5VDC for use within the device.
- Site Admin
The step down is a little black box on the wiring but I don't use any of this on my bikeRichard_R wrote: ↑Thu Feb 24, 2022 10:11 am The XT works and charges when connected to USB and USB is 5VDC so therefore the XT must require 5VDC. I imagine that there is likely to be a step down transformer (electronic type) within the XT or the XT mount to step the 12VDC from a motorcycle or car to 5VDC for use within the device.
I have this which has its own built in step down viewtopic.php?t=1318
The worry I have is if it goes wrong and applies 12v to xt
Ultimately it will fry the XT's brain. The only question is how long will it take to do that.
- Has liked: 1 time
- Been liked: 32 times
Stu, I hate to say it, but I doubt that there is any guarantee that Garmin's own power cable with built in 'little black box' couldn't fail and apply 12v to the XT.....Stu wrote: ↑Thu Feb 24, 2022 10:17 amThe step down is a little black box on the wiring but I don't use any of this on my bikeRichard_R wrote: ↑Thu Feb 24, 2022 10:11 am The XT works and charges when connected to USB and USB is 5VDC so therefore the XT must require 5VDC. I imagine that there is likely to be a step down transformer (electronic type) within the XT or the XT mount to step the 12VDC from a motorcycle or car to 5VDC for use within the device.
- Site Admin
That was my thinking and the reason why I questioned if they had a built in overload protectionelectro_handyman wrote: ↑Mon Feb 28, 2022 11:33 pmStu, I hate to say it, but I doubt that there is any guarantee that Garmin's own power cable with built in 'little black box' couldn't fail and apply 12v to the XT.....Stu wrote: ↑Thu Feb 24, 2022 10:17 amThe step down is a little black box on the wiring but I don't use any of this on my bikeRichard_R wrote: ↑Thu Feb 24, 2022 10:11 am The XT works and charges when connected to USB and USB is 5VDC so therefore the XT must require 5VDC. I imagine that there is likely to be a step down transformer (electronic type) within the XT or the XT mount to step the 12VDC from a motorcycle or car to 5VDC for use within the device.
It would be interesting to know but I'm not testing it
- Has liked: 1 time
Stu, I here you on that one... I dislike being the guinea pig as well.
Even at work I won't allow system updates to our BAS system until someone else has done them 1st.
