Page 1 of 2
Power overload cut off
Posted: Tue Feb 22, 2022 8:52 pm
by Stu
Does anyone know if the XT has a safety cut off feature in that if you apply too much power it auto shuts off to protect itself or will it be a case of if you apply too much voltage the XT will be toast?
I don't want to try it for obvious reasons
Re: Power overload cut off
Posted: Wed Feb 23, 2022 1:55 pm
I don't know, but I suspect not since the manual refers to replacing the in-line fuse - using a new fast blow fuse. If it had in-built circuit protection, I don't think that a fast-blow fuse would be necessary.
Posted: Wed Feb 23, 2022 2:42 pm
by iankim
I did read a post (
viewtopic.php?p=4755#p4755)
Apparently the user was running the XT via 12v and the only problem was the battery wouldn't charge.
I wouldn't try it just incase.
Posted: Wed Feb 23, 2022 5:22 pm
by Stu
I have searched high and low and can't find a definitive answer!
I have an adaptor on my R1200rt with a step down transformer and it always worries me that it goes wrong and applies 12v to the XT!
Posted: Thu Feb 24, 2022 10:11 am
by Richard_R
The XT works and charges when connected to USB and USB is 5VDC so therefore the XT must require 5VDC. I imagine that there is likely to be a step down transformer (electronic type) within the XT or the XT mount to step the 12VDC from a motorcycle or car to 5VDC for use within the device.
Posted: Thu Feb 24, 2022 10:17 am
by Stu
Richard_R wrote: ↑Thu Feb 24, 2022 10:11 am
The step down is a little black box on the wiring but I don't use any of this on my bike
I have this which has its own built in step down
viewtopic.php?t=1318
The worry I have is if it goes wrong and applies 12v to xt
Posted: Mon Feb 28, 2022 1:11 am
by Richard_R
Stu wrote: ↑Thu Feb 24, 2022 10:17 am
Ultimately it will fry the XT's brain. The only question is how long will it take to do that.
Posted: Mon Feb 28, 2022 11:33 pm
by electro_handyman
Stu, I hate to say it, but I doubt that there is any guarantee that Garmin's own power cable with built in 'little black box' couldn't fail and apply 12v to the XT.....
Posted: Mon Feb 28, 2022 11:44 pm
by Stu
electro_handyman wrote: ↑Mon Feb 28, 2022 11:33 pm
That was my thinking and the reason why I questioned if they had a built in overload protection
It would be interesting to know but I'm not testing it
Posted: Tue Mar 01, 2022 12:18 am
by electro_handyman
Stu, I here you on that one... I dislike being the guinea pig as well.
Even at work I won't allow system updates to our BAS system until someone else has done them 1st.
