SMART NOTIFICATION DRIVE APP AND ANDROID 12
giuseppe66
Has liked: 30 times
Been liked: 9 times
Italy
Post by giuseppe66 »
Hi, i've test (also with Garmin support) many phone and at today, app GARMIN DRIVE do not work with android 12, send only SMS and stop for others. Also the temperature that the Zumo XT shows does not correspond to that indicated by the phone even if in the same area and at the same time. The GARMIN DRIVE version not compatible with android 12 is the latest 4.18.47. If someone has a working solution after doing all the possible tests, please let us know. Thank you
Fxwheels
Has liked: 30 times
Been liked: 31 times
Re: SMART NOTIFICATION
Post by Fxwheels »
Sorry for not be able to help you, but I've learned long ago not to update unless the new "feature" will be absolutely of use to me.
If it's ain't broken - don't fix it.
giuseppe66
Has liked: 30 times
Been liked: 9 times
Italy
..infact it's right not update..thx but it's automatic in my phone
Last bumped by giuseppe66 on Fri Mar 11, 2022 5:49 pm.
