2 issues with Zumo XT
Gidi Ferder
Israel
Post by Gidi Ferder »
Hi everyone!
I just got my new XT. While loading it with my trips I noticed 2 problems:
1. No matter what order I loads them, the imported routes are listed with no logical order. Is there a way to edit the list of routes?
2. Is there a way to revert a route on the Zumo? (I know it can be done with BaseCamp)
Thnx
Fxwheels
Has liked: 30 times
Been liked: 31 times
Re: 2 issues with Zumo XT
Post by Fxwheels »
1. - I think it's no
2. - no. Possible in Montana but not in XT or 396
1. If using Basecamp, you can set the date for the first point of each trip. That has an effect on the order in which they are displayed.
Gidi Ferder
Israel
Wow!! So simple, so effective!
Great tip. Thanx!
