Car Mount for 660LM
kernowing
Has liked: 131 times
Been liked: 58 times
Car Mount for 660LM
Post by kernowing »
I want to hard wire my car mount into my car's fuse board rather than using the cigarette lighter socket/plug. Do I need a voltage transformer between the GPS mount and the fuse board or does the mount reduce the voltage?
Cheers, Pete.
2007 GL1800 Goldwing
Zumo 660LM
kernowing
Re: Car Mount for 660LM
Post by kernowing »
Just for information, in case anyone else was thinking of doing something similar, there's no need for a voltage reducer on the supply in to the 660 ;) .
Zumo 660LM
carolinarider09
Has liked: 28 times
Been liked: 38 times
Post by carolinarider09 »
My apologies, I should have or should be on here more often. But your answer is correct.
Thanks for posting the results for others to see.
