Hi,
I entered Iran a couple of days ago so my Europe maps don't cover anymore. I downloaded and installed the map of Iran from open street map and the map seems pretty detailed. My zumo just doesn't want to calculate routes on it. It calculates something, but really rough with only some edgy lines which I think represent only the mainroads in low quality vectoring.
Doe someone know how to setup the zumo so I can navigate comfortably in Iran?
Thanks all!
Cheers,
Maurits
openstreet map doesn't calculate routes
- Been liked: 1 time
- Has liked: 427 times
- Been liked: 934 times
Re: openstreet map doesn't calculate routes
You may have two maps for the same area ticked in myMaps.
If you have the OSM maps ticked, make sure that no other map is ticked if it covers any of the same area.
ha, that actually sounds pretty plausible. It shows OSM but uses the other, highly simplified map to calculate the route...
Will try today.
Thanks!
Will try today.
Thanks!
I unclicked everything except Iran map. Works like a charm now!
Thanks!!
Thanks!!
