Hi All
Can I save my waypoints into a separate Favourites folder on my SD card
And use them to create routs on the XT
Waypoints
Re: Waypoints
I don't know about saving them in a separate Favourites folder but know that you can save them to the SD card and them import them into the XT for use in routes. One caveat though is that there must be at least one saved favourite on the XT otherwise the XT won't show the waypoints on the SD card as available for import.
There is detailed information about this is in this discussion: viewtopic.php?t=1749&start=20
The link is to page 3 of the discussion. Details about waypoints and the SD card begins at the bottom of that page.
Re: Waypoints
You can allocate categories to your waypoints in Favourites. Categories show as separate folders in Favourites on your device.
This can either be done in BaseCamp or on the Zumo itself. Note categories won't show until you have 12 or more points in Favourites, at least that was always the case, whether it's changed on the latest Garmins I don't know.
